GordoSD said: (quoted from post at 18:37:25 07/29/09) Could I just remove the VR cover and see what the points are doing? Close them both "manually" using maybe popsicle stick,and observe the ammeter?
Gordo
Absolutely!
When gen starts to output a significant voltage ( above batt voltage) the cut out contacts should close.
When battery voltage is very low, the field contacts stay closed (for max output) & as battery charges up (voltage goes up) & field contacts begin to switch on & off at a rapid rate (like a vibration) and if battery is absolutely fully charged, the field contacts will remain open most of the time,( for minimum charge).
Bob's analysis would yield situation where field contacts are open all the time (hope not putting incorrect words in Bob's mouth).
And when engine is at a very slow idle or stalled, the cut out contacts open, disconnecting gen from battery.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
