Posted by mike sdak on July 29, 2009 at 16:45:07 from (64.68.172.110):
Hello.
I have a farmall SMTA, which I have owned for about 7 years. It gets run usually only in the summer, for mowing and light loader work.
The muffler fell off last summer - and I didn't replace the rain cap. I haven't attempted to start it until this week. I now can't it to turn over at all when I go to start it.
Two possibilities come to mind: 1. Weak Starter. I can hear the solenoid go, and the bendix (I think) engages, but doesn't turn it over. I charged the battery, and tried it with jumper cables too- no different.
I pulled the starter out 1/2" or so, and tried to push the rear wheels by hand - I didn't note any movement of the fan.
2. Stuck engine. I never thought that would happen in less than a year (famous last words). I am assuming this is the case, based on the apparent lack of movement of the fan when rocking the tractor. However, the rocking is limited, since I have a 3pt mower and loader attached, both resting on the ground.
Assuming no 2, I sprayed PB blaster in the spark plug holes, and down the exhaust, probably 3/4 of a can. No luck after two days (rocking or key-starting )
Thoughts?
Oh yes, the manual crank (shaft) is on the front of the tractor, but it seems the socket-end is frozen - it doesn't come close to engaging the pulley on the crankshaft. So I haven't tried crank-starting it, either.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
