Re: 300 utlity
Posted by Dellbertt on July 29, 2009 at 18:09:47 from (209.172.23.140):
In Reply to: 300 utlity posted by Bkpigs on July 29, 2009 at 15:31:00:
JimN is the resident expert on this tractor. There are several good posts in the archives on the 300U IPTO. Sounds like you have considered the usual problems that cause heat, low fluid, air, blocked screen, stuck relief valve, etc. Now you just have to check them. One thing I learned while troubleshooting hydraulics is that a pressure guage at the coupling will tell you a lot in a big hurry. Also, the 300U is notorious for problems caused by worn and sloppy IPTO linkage. Here is a post I wrote a while back on adjusting, if you do not have a manual.
Dell
Most IPTO are similar on older Farmalls and IH. Here are some important things I learned about adjusting them.
When you have the linkage apart take the time to tighten up any slop using washers and tightening any loose nuts. This is major important.
1.Disconnect the bottom adjustable link near the IPTO housing (a cotter pin and a pin).
2.Remove the peanut shaped cover over the two adjusting screws (if it is there).
3.Then tighten the two band adjusting screws until you feel resistance then another ˝ turn. This seems to “center up” the band linkage. (the front screw is the operating band and the rear is the anti creep band).
4.Now the book says to have someone hold the control lever in the center position (between engaged and stop) while you readjust the adjustable link and reattach it. There is supposed to be a punch mark to line up for center, but I couldn’t find it so I just put it in the center between the on and off notches.
5.Put a small screwdriver or bolt through the PTO shaft hole and loosen both adjusting screws until the shaft moves freely. Alternate adjusting until you get both screws adjusted properly so that the shaft moves freely ONLY with the control lever in the center position.
6.Move the control lever to on and off positions (make sure the lever clicks in each stop) you should not be able to move the shaft with the control lever in the engaged or stop position but it should turn freely in the center position.
Note: I didn’t have anyone to hold the lever in center position (4) so I readjusted and connected the adjustable link with the lever in the off position then move the lever to the center position while adjusting the band screws. It seemed to work that way.
I hope this helps anyone without a manual.
