Posted by screwstick on July 29, 2009 at 19:02:27 from (75.89.23.145):
In Reply to: cub 154 low-boy posted by stephen roberts on July 29, 2009 at 17:28:14:
Before advice can be given, you should do a compression check, wet and dry, check the valve clearances, direct oil pressure check and do a tune up; plugs, points, rotor, wires, cap and coil (the works). Check timeing as well.
This will be much cheaper than rebuilding or replacing the engine. If all is bad, I would rebuild the engine if the clutch, PTO and mower deck are still in good shape.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
