Re: 1941 farmall h
Posted by rustyfarmall on July 30, 2009 at 06:37:16 from (209.152.78.140):
In Reply to: 1941 farmall h posted by Russell Grieff on July 29, 2009 at 20:10:00:
Russell Grieff said: (quoted from post at 20:10:00 07/29/09) yes i seen it on the ih site it lists all the parts from the first year right up till the last year but it does not tell you exactly witch one was used in what year like for example the pto i have a 41 and a 40 and the 41 has a little pto and the 40 has a big one was it changed or is it all in how it was ordered from the factory and yes they did make a kerosene model it started on gas then you switched to kerosene it is like the distillate but used kerosene if it has x3 on the serial tag it means it is a kerosene tractor check this website out it gives alot of info on that part http://www.farmall-h.com/ check the dateing your h section or if you got a it shop manual it tells you in there
Also you want to keep in mind that the P.T.O. was optional, and the tractor may originally come from the factory WITHOUT a P.T.O. and then it was added later but not until the later style was being used.
