If you have the rigid steel lines, like my 400, the smaller diameter line is the pressure line. The larger line is the supply line. To prime mine, I took the set screw off the pump that is over the relief valve and kept adding HY-TRAN until if would not take anymore. It will drain down a few times before the lines are full. Just be sure that the setscrew does not get cross threaded, because it does not sit in the housing straight or flat. I wrecked one that way. Steve
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
