Re: Zenith carb ID
Posted by Chris from Wa on July 30, 2009 at 22:58:32 from (71.212.21.189):
In Reply to: Re: Zenith carb ID posted by john *.?-!.* cub owner on July 30, 2009 at 19:53:24:
Overhead valve. The engine appears to be a C123, but I haven't pulled the head to verify the displacement. The engine was installed in my Super C, before I bought it, when the original engine ate the teeth off of the timing gears. Even though the replacement engine bolted up and worked, the block casting is different and doesn't match up perfectly to the tranny. It could be off of a harvester or combine, who knows?
