Thanks for your excellent description Owen. It looks like my problem may just be wear and tear or age and not the hydro itself. It's probably a combination of wear on the plates and on the valves themselves. I still need to cap the lines to be sure it's not in the external controls and I plan to do that ASAP. My next question is, if it should be that the charge pump or motor plates are scratched or worn can they be replaced? What needs to be done to get to them and replace them? Thanks again for all your help. I will print out all the replies I have received and show them to the mechanic I plan to have do the work so that he can review them before tearing into the tractor.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
