Re: Removing crank pulley from Super C
Posted by gene bender on August 01, 2009 at 09:22:11 from (67.55.227.88):
In Reply to: Removing crank pulley from Super C posted by Mark-Mo on July 31, 2009 at 19:00:58:
You do jnow that the steering sector has to be removed to pull that pulley and when you get the pulley off check the journal to make sure the old seal hasnt left a groove in the pulley. You can get a heavier seal from Car Quest that is much better that the replacement on you will get over the counter.
