Re: timing on farmall A
Posted by CNKS on August 01, 2009 at 12:47:19 from (216.144.104.128):
In Reply to: timing on farmall A posted by d shipp on August 01, 2009 at 08:46:12:
Another version -- With mag out, turn rotor or drive in the front until the rotor is pointing at #1. You will feel resistance, any more movement and it will trip. Carefully install mag making sure that the gear engagement does not move the rotor. Once it is engaged, set the top of the mag (coil) next to the block. Pull it away from the block until it trips and tighten. Best to check the timing marks under the tractor, but they can be very hard to find. As Pete said you must have #1 at TDC before doing this. Timing with a mag is no different than with a distributer -- except that with a distributer you must watch for a spark. With a mag, you can feel/hear the trip which is when the spark occurs.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
