Re: Farmall M Overcharging Problem
Posted by Janicholson on August 01, 2009 at 16:47:17 from (64.61.211.127):
In Reply to: Re: Farmall M Overcharging Problem posted by Jim R on July 31, 2009 at 21:48:26:
A volt meter is about 15 bucks (get a needle type) from Radio Shack. A good amp meter to check the one you have in it will be more (auto parts amp meters read more like 50 + and 50 -, so it will give a clear reading on just how much it is really charging. 7.2 to 7.4 volts is great. To check the amp meter, (they do get to reading high as they age) replace it with a new one using the same terminals as are connected now. JimN
