Posted by Hugh MacKay on August 01, 2009 at 19:39:47 from (209.226.247.188):
In Reply to: F 140 loose steering posted by bigdiesel on August 01, 2009 at 10:31:35:
bigdiesel: Is the any end movement of steering shaft, if not those bearings are fine.
Two woodruff keys on the vertical shaft are very likely your problem. One on gear inside, the other on steering control arm. I've seen those two keys give 1.5 turns of free travel on steering wheel.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
