Posted by El Toro on August 02, 2009 at 06:11:37 from (205.188.116.73):
In Reply to: M engine out there? posted by TedD17 on August 01, 2009 at 21:36:46:
You would be better off to rebuild your engine. Then you would know what you have. Pull the engine and have the crankshaft measured for wear to see if it needs to be ground undersize. Your local auto machine shop can determine that very quickly. They can supply the correct bearings too. Have new cam bearings installed. New sleeve & piston kits are readily available. Have the head redone too. It will then last a long time with a lot of care. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
