Likely M&W, aftermarket, dealer or owner installed. It gives you a "live" PTO in that when you pull the lever back the tractor stops but the PTO keeps turning. You still have to push the main clutch to shift gears. M&W and Heisler also made 9 speeds which give 2 ranges in gears 1-4, 5th was not effected. The additional speeds occurred above the 5 mph 4th, ie 1st high was more then the normal speed in 4th. With both the low first and the M&W PTO, your tractor is worth more than the usual H, provided they both work properly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
