Posted by Red Dave on August 02, 2009 at 07:26:20 from (98.235.15.235):
In Reply to: 1947 BN Clutch Problem posted by Jim in Britton, MI on August 02, 2009 at 05:22:36:
I'm sceptical that you can even get the clutch back together with the disk in backwards. I deliberately tried it once to see if it can happen, and couldn't. The Pressure plate bolts are too short.
It sounds like your throwout bearing isn't pushing on the pressure plate fingers hard enough to release the clutch. Did you back off the clutch adjustment to disassemble then forget to re-adjust it? Did you reassemble it correctly? You may have to take it back apart and see what is wrong.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
