Re: Rear ballast on 1466
Posted by 61-4010 on August 02, 2009 at 10:24:32 from (74.171.25.210):
In Reply to: Re: Rear ballast on 1466 posted by Hugh MacKay on August 02, 2009 at 04:25:17:
I have to use what I have that will fit the bill. The 1466 is the only tractor I have that will be able to pull a 12 foot chisel plow and 24 foot disc. And because it has dual hydraulics and 1000 PTO, it will run the haybine well.
Doing hay, I don"t till my soil regularly...so the traction for hard field work is only needed when fields need to be restored from the bottom up. And when that is needed, I"ll put the duals on her.
Trying to make use of what I have effectively. I"m not made of money and can afford to have a specialized tractor for everything I do. So we meet somewhere in the middle.
Back to the dark ages I go...now where did I put that dang candle????
