Re: cub gas tanks
Posted by gene bender on August 02, 2009 at 13:08:58 from (67.55.227.88):
In Reply to: cub gas tanks posted by hoopy on July 31, 2009 at 10:09:59:
Sand the area clean down to bare metal and then get a fiberglass kit it will never leak again. If they are rusted thru you will need to seal the inside as there must be some rust that can plug the sediment screen. You can put a small standpipe on the sediment bowl inlet that will help keep the junk at the bottom of the tank from getting into the sediment bowl assy.
