Farmall H Hydraulics
Posted by Jay Poole on August 02, 2009 at 15:21:41 from (129.252.69.53):
I'm attempting to use a JD pull type disk behind my H, it has a hydraulic cylinder on it to adjust the gang angle. I have a double action cylinder on it and know I need a vent on it if I'm using it with the lift-all pump... my question is where can I find or what do I use to make a vent to screw into the other hose port on the cylinder? I now have the hose hooked to the rear left fitting of the tractor and it will only work if I stop and relieve the pressure on the end of the unused hose ( I have the Pioneer type fittings on it ). We use this disk with our B John Deere so I would like to keep the double action cylinder.
