Farmall H electrical system
Posted by Chris S. on August 02, 2009 at 16:43:32 from (68.54.144.92):
I recently purchased a 42 H, the seller was not the original owner and he said that he thought that the tractor had been switch over to 12 volt. I replaced the battery and was informed that it was using an 8volt battery. Even with the new battery the tractor still lags when turning it over. Tonight i had to really work with it just to get it to turn. How do I tell if the tractor has been switched to 12 volt. I'm assuming using an 8 volt battery on a 12 volt system would be causing the tractor to lag on start up like its doing. Thanks in advance.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
