Re: quick paint question
Posted by CNKS on August 02, 2009 at 18:04:30 from (216.144.104.128):
In Reply to: quick paint question posted by IndiRon on August 02, 2009 at 17:50:51:
Hardener contains isocyanates, which are not filtered out by the usual charcoal mask. You need supplied air $$$. If you use hardener you might as well use urethane paint as it is longer lasting and more durable than the cheaper alkyd enamels. Do you have to use it? No, it is required only with urethanes which will not cure without it. For other opinions ask your question on the Paint and Bodywork Forum on this site.
