Re: Farmall C step
Posted by Gnellist on August 02, 2009 at 19:03:26 from (70.41.38.165):
In Reply to: Farmall C step posted by bigr on August 02, 2009 at 17:54:22:
I had a Super C a few years ago and it had two "L" shaped steel brackets in front of the axle with a wooden plank bolted across under the torque tube so you could step up from the front. I had the rear wheels out far enough to provide room. The "L" brackets bolted to the front side of the implement brackets and did not interfere with any rear mounted implements. I usually got on from the left side - put up the right foot first on the plank, then the left on the platform and swing the right either over the seat or between the seat and the steering wheel.
Worked so well that I later fabricated a similar step for my Kubota. Was a great help to these old legs!
