Posted by bc on August 03, 2009 at 10:34:22 from (71.158.218.38):
In Reply to: Hydraulic Flud posted by John Athey on August 02, 2009 at 19:36:35:
I use the Orscheln 303 brand in the yellow bucket. I believe it is 20 wt and meets all specs. They run it on sale every 2 or 3 months. This week it is $22 a 5 gal bucket. TSC has always want too much for their brand and there is nothing that says it is better than any of the others that meet the same specs. Just compare them. Some may be a different weight though. As long as it says it meets all IH specs and others.
Main thing is too keep moisture out of it. Long periods of heavy field work heats it up and dispells the moisture (the milky look and slimy feel). Kinda hard to do for a part time loader tractor which means extra oil changes. With your lines, cylinders, and draft control housing holding a few gallons, it's near impossible to change it once and clean it up. Between condensation and rain leaking around the shifters, water is always getting in. More oil changes means more money depending upon how rich you are.
To answer your question, I haven't heard anything bad about TSC hytran. Used to use it in my 460 years ago. I think it is over priced. Like motor oil, many brands are made at the same canning plant. You can compare the size and style of buckets, tops, and spouts to see if they were made off the same type of assembly line.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
