340 Hydraulic issue
Posted by jaybird2 on August 03, 2009 at 11:14:16 from (170.202.22.1):
Hello folks,
I"ve got a 340 rowcrop. Over the winter the pump went bad and I found that the whole system was full of crud. Replaced the pump and had the hydra touch control valves broken down and rebuilt, replaced the filters, got it all back together and primed the pump and it now works, sort of.
One control valve seems to be open, even though the lever is in the neutral position. I can hear the tractor under load. The other valve works as it should.
Is there an adjustment I can make or is something put together wrong? My guess is that the valve was put together wrong, but I didn"t think that was possible... I"d really hate to take it all apart again. just wondering if you guys might have run into this before and might know what to do.
Jay
Duelm, MN
