Re: Farmall M Hydraulics- pics please?
Posted by mkirsch on August 03, 2009 at 12:26:03 from (64.80.108.57):
In Reply to: Farmall M Hydraulics- pics please? posted by n9viw on August 01, 2009 at 17:42:31:
The way you describe the plumbing, you have a CORRECT two-way hydraulic setup. Your 3pt will power up and power down.
All you need to do is secure the Liftall lever back so that it is providing pressure. Hooking that nub on the lever should work, but maybe the linkages are worn. How much further do you have to pull it to make it work? Maybe weld a piece of key stock on the rod to take up the slack?
A bungee cord could be used to hold the Liftall lever back, or you might be able to secure a small hose clamp on the rod to hold it pulled back, but beware if you have to force it ahead for some reason, you won't be able to.
You will need to use collars on the cylinders to limit height. There is no position control available, unless you sit down and design it yourself. It drops down because you have a leaky christmas tree valve.
