Re: I screwed up again...help!
Posted by mpuller on August 03, 2009 at 14:36:20 from (70.35.66.180):
In Reply to: I screwed up again...help! posted by TedD17 on August 02, 2009 at 20:00:05:
With #1 @ TDC on compression, adjust 1, 2, 3, & 5.
Rotate 360 degrees, then adjust 4, 6, 7, & 8.
