Posted by mattofvinings on August 03, 2009 at 14:43:51 from (67.142.161.29):
In Reply to: Head bolts posted by Bill in IL on August 03, 2009 at 12:54:33:
I have used Grade B7 threaded rod to make head studs before. This steel very closely approximates a Grade 5 bolt. I ordered it from McMaster-Carr
The studs are still running in a Continental flathead engine in one of my forklifts. The way I use it is not quite the duty cycle of a tractor but I don't see a good engineering reason why it should not work. The torque specs will probably have to be adjusted if the stud is all coarse thread and the original setup used a fine thread.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
