656 D utility
Posted by Tony L on August 03, 2009 at 18:10:30 from (76.177.147.212):
1968 model with the TA lever on the left side. It is so stiff that I can barely pull it back and forth. It works fine but its stiff. I looked for a grease fitting and cant find one. I sprayed penetrating oil all over it and it is still stiff. Is there supposed to be a grease fitting or what else can I do. I looked in the manual and found the fitting for the gear shift but not the TA.
