Re: cub governor will only advance halfway
Posted by screwstick on August 03, 2009 at 18:39:22 from (75.91.82.90):
In Reply to: cub governor will only advance halfway posted by jrgkribel on August 03, 2009 at 17:33:56:
There is a difference between the throttle and the governor. If the throttle is hard to advance, check for binding on the governor rockshaft. Spray will penetrant and work back and forth. If still no good, you may need to remove the rockshaft and clean it.
The governor will not advance the RPMs higher than what the throttle lever is set to. Before you take the governor apart, check for binding and lubricate the linkages.
