Re: Fast hitch down pressure
Posted by Heifer Raiser on August 03, 2009 at 20:57:54 from (166.137.133.56):
In Reply to: Re: Fast hitch down pressure posted by wolfman on August 03, 2009 at 20:00:18:
Thanks Wolfman! I will take a look and try to figure it out. I was also told that there is a valve that can be adjusted from double acting to single acting in close proximity to the spool valves. Will that work? Thanks. Jake
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
