Re: Farmall M Overcharging Problem
Posted by Jim R on August 04, 2009 at 05:37:01 from (209.181.185.49):
In Reply to: Farmall M Overcharging Problem posted by Jim R on July 30, 2009 at 21:57:29:
Again, to all who responded, Thank You! I just wanted to post what the end result was. I finally loaded up the tractor and hauled it to the local Auto Electric shop in town that is the best around. They checked out the tractor and said that it has a 6 volt generator on it. It seems that at one time one of the previous owners at least attempted to convert it to either 8 or 12 volts, and they had tweeked the voltage regulator up so that it was putting out about 10 volts at full throttle. The tractor now, as I said, has a 6 volt battery hooked up to positive ground, so the technician just advised me to replace the voltage regulator with a new 6 volt regulator and I should be good to go. Thanks again for all the responsed, It has been a real learning experience for this electrically challenged guy!
