Valve setting I do it this way others do a different system. It must be set cold first, so setting it twice (ore once) is normal The cold setting is .020" all valves. Take out the plugs. (turn it with a wrench, on the front nut) Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open. Set the exhaust when the intake just closes. This is the two positions that can be seen on each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is. The order is (front to back EI-IE-EI-IE) Repaired instructions, My appology!! Look at #1 valves, Turn the engine till the exhaust just starts to begin opening (moves) then adjust the intake valve. Rotate more until the intake just closes (just stops moving after having been open) and adjust the exhaust. Treat every cylinder (pair of valves shown above the same way, remembering they switch places between cylinders) I put a rag over the ones I have dobe to keep track of progress, and avoid mixing what I am looking at. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
