F 14 fuel system
Posted by JLE on August 04, 2009 at 11:18:57 from (68.28.138.247):
F 14 starting problem. pre messages said to check for float hieght, that should be how much. This 14 starts hard cold, good when warm,have checked timing, new coil, poins & condensor,impulse snaps loud and clear. And as usual only pull few feet to start. Pulled carb this AM and it was bone try.
previuos note on changing manifold from hot to cold. Where is this located??
Also it has a tee fitting at top front of fuel tank, pressure line fuel pump to it and aline to the carb. what is the purpuse of this fitting??
