Re: Couple of Farmall M Questions
Posted by Janicholson on August 04, 2009 at 12:52:07 from (64.61.211.201):
In Reply to: Couple of Farmall M Questions posted by Kerwin on August 04, 2009 at 10:27:00:
To be perfect, drain all the fluid out, and put in 6 qts. Mark the stick. I think the stick is 8" long and is marked at about 7 inches for full. The system does not care much unless low enough to starve the pump. The rod should be 1/8" steel with the top going through a fabricated washer with a 1/8" hole in it that fits inside the cap, and onto the top of the stand pipe. The washer is held on, on the factory stick, with a deformed spot above and below the stick. JimN
