Thanks to everyone for their advice! I seem to have just fixed the problem. I removed the flow divider plug & spring, and found that the flow divider was stuck.
Using a drill bit as an "EZ OUT", I was able to pull the flow divider out most of the way. Could not remove it because of hydraulic lines, so I just moved it back and forth several times with a screwdriver. It moved easily all the way in and back out. I put spring and plug back in and everything now works fine.
I don't know what caused it to stick. It may do it again, but at least now I know what the problem is.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
