Re: Cub Eng. rings
Posted by El Toro on August 04, 2009 at 17:07:11 from (205.188.116.73):
In Reply to: Cub Eng. rings posted by Darock on August 04, 2009 at 08:39:18:
When you get the pistons out you should push your new ring in the cylinder and measure the ring gap.
The compression rings should be between .007-.017". The old one piece oil ring is .007-.015".
They're probably now using the 3 piece set with 2 rails and an expander. You need to use a ridge reamer to remove the ridge at the top of the cylinder so you don't break a piston. I would use a glaze breaker on the cylider walls too. I would prime that oil system before you make a start to make sure you have oil pressure. If that block is sludged up I would pull the engine and take a look at that oil pump & have the block cleaned. You probably should have the crankshaft measured for wear. Hal
