Re: Air filter toubles
Posted by rustyfarmall on August 05, 2009 at 06:13:15 from (209.152.78.140):
In Reply to: Air filter toubles posted by MN Jerry on August 04, 2009 at 20:46:38:
The filtering media can be removed from the canister by drilling out the spot welds, but then you have to weld it back in. A better way is to remove the entire assembly from the tractor and place it in a 5 gallon bucket. Fill the bucket with diesel fuel and let it set for a day or two. You may want to agitate it every so often, then remove the canister and set it somewhere so it can drain and dry.
