Re: Farmall H fan belt adjustment
Posted by glennster on August 05, 2009 at 07:24:18 from (99.131.131.158):
In Reply to: Farmall H fan belt adjustment posted by grasscutter on August 05, 2009 at 06:10:14:
if you are talking about the big belt that drives the water pump from the crankshaft, the top pulley on the water pump is where you need to be. the pulleyhalf nearest the fan is threaded and the half unscrews toward the fan. there is a small bolt with a locknut that goes thru the pulley to a flat area of threads on the water pump other half of the pulley. remove the bolt completely. soak up the threads real good with your favorite penetrating oil. then soak er up again. there is a raised boss a little ways around that pulley, i use a brass drift to tap the half loose. unscrew it toward the fan and the belt will come off the crank pulley, then you can work the genny belt around. here is a pic, this is an m but the same deal
third party image
