I didn't double check, but I think M was the standard suffix for these [pretty sure everyone I've seen]. You're smack in the middle of the '29; about half of the updated 15-30 [22-36] were '29.
If it was stored in a barn it's whole life, and didn't get excessive hard use you may have a pretty nice speciman there.
Side curtains are hard to find, and I don't think anyone is selling reproductions right now, but if you can find a hood, tieing it down with wire does have a certain historical appeal though not factory correct.
If you want to use an F-4 mag, dime/dozen is only a slight exageration - you can get it fixed or traded for likely under $100. I believe 29's should have an E4 [and I like the look at that], which are easy enough to find, but could cost several hundred if you want it rebuilt.
Starting tanks can be had easy enough [I think the rebuild kits are around $75 if you have the base yet], also, you'll likely want road rings or rubber tires if not plowing with it, so I'd consider the lugs a non-issue.
What manifold? Exhuast come out by the air-cleaner or does it go straight up? The former is original, though the aftermarkets I understand are just as desirable to some people - so I don't pose the question as that of value, but the latter would make the starting tank mute.
Don't know about your area, but a non-running one around here won't likely fetch over $500 as you can easily put 10X that into it; your find might be worth a bit more if everything looks pretty well there and tight.
This post was edited by spiffy1 at 08:19:03 08/05/09.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
