Newbie tool question
Posted by Rossputin on August 05, 2009 at 09:12:18 from (72.42.107.108):
Hi Gang,
I'm pleased with myself for having changed the oil and filter, flushed the coolant, and replaced the fan belt on my '41 Farmall B.
Now I want to change the transmission/differential oil and the wheel bearing oil.
So, two questions:
First, the plugs for the transmission oil have indented squares that look somewhere between 9/16" and 5/8" wide. What is the proper tool to open and close those plugs?
Second, where do I drain and refill the oil for the wheels? I've looked at the wheels and the manual and still can't figure it out!
Thanks as always for all your help.
Ross K
Nederland, Colorado
