Farmall 706 tranny issues
Posted by BTrask on August 05, 2009 at 11:40:53 from (64.222.203.187):
Tractor will not move after changing filter and oil. Worked fine before; however, the TA never worked good. Always left it forward. PTO works, lift arms work, brakes work small amount, steering works small amount, and tractor will move only a few inches both forward and backward.
Tried dumping oil down cooler lines to perhaps prime the pump.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
