706 emblems and injector pump leak at line
Posted by andy r on August 05, 2009 at 12:25:30 from (69.66.71.73):
I recently purchased a 706 diesel and the side panels say "International". My other 706 says "Farmall". Both are row crops. Is International correct????
Secondly, on the diesel it is shooting out a small stream of diesel fuel (not high pressure at this time/just a small stream) at the injection pump where one of the injector lines hooks on. Looks like the pipe hooks to a circular fitting and a bolt goes through the center holding the fitting tight to the pump. Does it just need to be loosened and retightened? Sanded? Filed flat? "O" rings?? Thank you.
