Re: FARMALLS AND LOG SPLITTERS
Posted by Bob M on August 05, 2009 at 13:34:08 from (151.190.254.108):
In Reply to: FARMALLS AND LOG SPLITTERS posted by PRTZMAN55 on August 05, 2009 at 12:53:02:
I use a pull-behind for the same reasons Bob points out.
However I have successfully powered a pull-behind from larger Farmall (SH and SM) hydraulics. The Supers work the splitter fine but are kinda wasteful on fuel.
Your 200 will probably work. However with its smaller pump you may find it strokes the ram too slow for your liking.
I doubt however the Cub is up to it. It's modest hydraulics are intended only to lift mower decks and such.
This post was edited by Bob M at 13:35:05 08/05/09.
