Re: FARMALLS AND LOG SPLITTERS
Posted by IH fan on August 05, 2009 at 15:16:46 from (208.189.46.178):
In Reply to: FARMALLS AND LOG SPLITTERS posted by Matthew Williams on August 05, 2009 at 12:53:02:
Advantage of a pull gas powered splitter is most have a two stage pump... fast stroke to log and step down flow for more pressure to split, high flow to reverse the cylinder. Speeds up the cycle with less HP and less fuel.
