Lesson Learned
Posted by eastsider on August 05, 2009 at 18:17:51 from (24.111.62.102):
In the process of putting my H together from being totally taken apart, we got to the stage of re-assembling all the large chunks last night. Of course, a new clutch and pressure plate were part of the process. After bolting the entire tractor together into a rolling chassis, we figured out the clutch fingers weren"t adjusted correctly...so we split what we had just put together, and found that the new pressure plate fingers couldn"t be adjusted to the full height needed...after a trip to IH this morning, a new replacement was obtained and we were able to adjust it correctly...it is amazing how much difference a few parts of an inch makes on those fingers! So, if you ever put in a new one..check it out...they don"t have it set right from what I have seen! The picture is what it looked like just before we put it back together this morning...progress is slow sometimes!
Mark
third party image
