Did a little research...
Posted by Crazy Red Power in SE-WI on August 05, 2009 at 18:52:04 from (24.183.138.183):
In Reply to: PAINT the muffler?! posted by Crazy Red Power in SE-WI on August 05, 2009 at 17:24:03:
in some back issues of Street Rodder. It seems I have 2 options: 1. Use BBQ black as a base coat for whatever color (ex: ford blue) you need to apply. 2. Sandblast whatever surface you are applying hi-temp paint to. They both emphasize cleanliness & prep. Also, don't use anything less than 1500dg if comming straight off the header. My uncle sez there's a black (I hope) paint made by Deere for hi-temp applications. Supposed to be pretty good. Hmmmmmm, I guess it's trial & error. Thanks much, guys! - Mike
