Good technique. With one out you have a "guide" as to how deep to cut on the remainder.
With surgical precision, you could employ a power tool for the "roughing" cut and then finish with the hand blades. You can cut more deeply into the water-bathed area but be sensitive around the top and the o-ring seal.
Any kind of a weak spot you can generate is going to give the cast a place to crack. The kerf is better as it allows the halves to pull radially away from where they are stuck.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
