Re: Ammeter - Which way should it point?
Posted by Vfmerc on August 06, 2009 at 06:01:22 from (71.188.48.104):
In Reply to: Re: Ammeter - Which way should it point? posted by rustyfarmall on August 06, 2009 at 05:54:53:
Will do. Once I've got it deflecting to the left (lights on, engine off)
1. Should I expect to see the needle deflect to the right of "0" when the engine is running if the generator is "charging" a depleted battery?
2. Would you recommend running with the switch in the "low" charge position?
Vfmerc
