Re: 656 Hydraulics Quit
Posted by cd1 on August 06, 2009 at 07:48:11 from (67.238.39.68):
In Reply to: Re: 656 Hydraulics Quit posted by Formerly PaMike on August 05, 2009 at 18:58:04:
since the 3 point works, you can rule out your pump not turning since the hitch pump drives off the main pump. i'd imagine your pump went bad but you should have the hydraulics tested first.
