Posted by Janicholson on August 06, 2009 at 10:26:08 from (64.83.208.148):
In Reply to: Smdta elec issues posted by BOBM25 on August 06, 2009 at 08:59:35:
orrosion is caused by electron flow. Cleaning in a damp environment will temporarily fix it, but it needs a clear spray, or terminal spray on it to keep the moisture out. If it goes dead, thee is a drain on the system. It can be tested with a vlot meter set to 2 volts or lower. Disconnect one battery terminal, then check the voltage between the terminal, and the post. If more than .02volts, there is a draw. Disconnect things one at a time to find it. (reconnect as you go) JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
