Re: cub timing?
Posted by Dave from Texas on August 06, 2009 at 13:39:05 from (144.177.70.5):
In Reply to: cub timing? posted by stonestacker on August 06, 2009 at 08:02:43:
Mine has a magneto. I followed the manual to ensure the impluse triped at TDC and that the rotor was pointed at the number 1 cylinder. It was still off. I used a timing light and found that the gear on the mag drive was not matched with the cam gear. Correct that and the timing light show it was correct. Started and ran a lot better. Hope you have a manual for step by step instructions.
